Advice for data recovery from GPT drive.
stephenp
63
I know there's a sticky about this which I read, but with all of the software options I am wondering if people have suggestions for their favorite recovery software to try first. Unfortunately time is of the essence right now for me. 🙁
I believe I mistakenly put my data drive into my RAID tower which formatted it and set it up for RAID1. Of course I then copied about 1GB of data to it before realizing my fault. It's a 3TB drive which must have been formatted with GPT both when it was simply an external drive (with my data) and again formatted when I created the RAID.
I know partition recovery is out of the question. And maybe even directory structure, but I'm hoping to recover at least the actual file names (and HOPEFULLY) some of the structure as well. I believe there is about 1.5TB of data I would like to recover.
I am of course not writing anything to the disk.
I used Recuva as it's always been an awesome tool. It found a ton of files after running 10 hours over night. I'm recovering those now. Unfortunately it named most of the files [000123.xx] which is better than nothing, but will be very difficult to sort. And there is no directory structure.
I tried EaseUS Partition Master (which includes a data recover program) to look at the drive. It found some structure still in tact and even real file names! Unfortunately it's only seeing the 3TB drive as 700GB (or so) which I understand has to do with the drive being GPT formatted - it looks like EaseUS can't see the drive in it's entirety.
I've read that I can try Pandora Recover, Glarysoft Glary Undelete, and DMDE for example. I'm open to paid software too. I guess I'm just wondering if any of you have had great luck with any of these specifically which you would encourage me to try FIRST. I don't mind trying all of these softwares (or even paying for "Pro" versions as well). But, of course I'm under a time constraint and if it takes 10 hours for each software to scan, I fear I may be wasting a lot of time with trial an error... which might end up being the way to do it anyways...
Any recommendations would be GREATLY appreciated!
Thank you!
-Stephen
Thanks for the quick reply Yadhu! I'll check it out! Because I created a new partition (over top of the old one) when I created the RAID1, do you think this would still recover the OLD partition? I'm still recovering files right now with Recuva but as soon as it's done I take a look at this.
Any other suggestions before I start trying these one at a time?
Thank you!
A couple I've tried are Stellar Pheonix Windows Data Recovery and Kernelfor Windows Data Recovery. They're both paid. It's been a while since I've used them but I think Stellar Pheonix was the better. However, I have never tried either with GPT partitions or drives bigger than 2TB so have no idea if can do what you're asking.
Thanks for the advice! I'm still scanning a deep scan using EaseUS Data Recovery Wizard. It estimates 20 more hours of scanning (been scanning for 10 so far). Recuva scanned for 10 total, so hopefully this is not wasting 20 hours but rather finding more (especially real names) than Recuva.
Thank you again for the recommendations!
