Advice for i5-2500 Build
tryn
45
I want advice on any last minute tips or recommendations
Approximate Purchase Date:today
Budget Range:$550-610 ish
System Usage from Most to Least Important:gaming,gaming,gaming
Parts Not Required: operating system
Preferred Website(s) for Parts:newegg.com
Country of Origin:USA
Parts Preferences:i5-2500, 8 gigs of ram, 6850
Overclocking:no
SLI or Crossfire:no
Monitor Resolution:1900x600 or a little higher
Additional Comments:I want advice on any last minute tips or recommendations
Here's what I've come up with so far:
i5-2500 $210
powercolor 6850 $160
nzxt gamma case $36
corsair builder 500w power supply and corsair xsm3 2x4 RAM combo $93
sony dvd burner and saegate 500gb hdd $54
Asrock H61-VS motherboard$55
total: $608
Dont take this offensively, but oh boy we got work to do lol
First let me just mention that with that case you only get a single rear fan. You would need to buy a few more fans and install them so that nothing over heats. (i can go into more detail with this if u wish just ask)
Second the builds not terrible so dont think it is...
third you need a bigger PSU period. The recommended PSU for the 6850 depending where you look is 450-500, therefore you need atleast 600.. I would said 650 to be safe. Someone can correct me if im wrong but thats just my personal opinion. Id rather have extra power then not enough 😀
I plan on adding an 120mm fan in the front and another on the top.
I also used the extreme and newegg power supply calculators with 30% capacitor aging so I think 500 corsair watts is enough since I don't plan on doing any overclocking and updating. I am also new to gaming, is a 21.5 monitor big enough or should I spend more on a 23 inch?
honestly for gaming id say 23" however you wont notice much difference with a 21.5 and I dont think it would affect your gaming performance either way. Also I was just giving suggestions so you could be right, and if you dont OC or anything 500 should be fine your right.
Not a problem that's what these forums are for. Ive learned alot from everyone here and its only fair to pass it on. Come back any time (most of us tend to be here every day 😵 lol)
look out for me on starcraft : PreciseDeath
wait a week though I still need to get the game and the computer haha
i just assumed he ment 1920x1600
Ya I just figured maybe he had a weird 1. either way i dont think it really affects the build much since either way the build will run both
Hmm I think it would but i think he indirectly said he ment 1600x 900
^ Yeah, in any case your build is solid tryn! Drop down to the i5 2400/2300 to save a bit more money and you'd be golden, the 2500 is a bit of a waste since the 2400/2300 would perform similarly. That little difference in clock speed would make little diff.
Is there a noticeable difference between the i5 2500 and the i5 2300?
I am for sure going to drop down to a 2400, but 2.8 ghtz seems kinda low even though it's an i5.
What do you think?
Yeah, I'll just go with the 2400. And I've decided go with the builder 600 power supply since it's only $10 more. Thanks for all the advice.
Any last advice before I hit checkout?
