Advice for part upgrades?
Biglemon29
113
Hi this is my current build https://pcpartpicker.com/user/biglemon29/saved/XbCqqs
I've been having some performance issues with it lately and wanted to upgrade some of the parts. This is for a gaming PC. I was wondering if I could get away just upgrading CPU, GPU, mobo and ram? What would you recommend for this? I need something to handle 1080p games well such as Battfield 1, Fallout 4, GTA 5, ect on nicer settings? I am pretty sure my psu is fine and my SSD but how should I know to replace these?
While you could switch CPU and motherboard as well you could get a significant increase in performance by getting a higher end graphics card, because while the FX-8350 isn't a major powerhouse it does a decent job at handling most games, the only issues it can run into vs a i5 or i7 is in really CPU intensive games. You can pick up an RX 580 for around $200, some even in the $185 range and that should be plenty powerful enough to run most games on Max or Very High at 1080P.
Really, you could just upgrade that GPU. The RAM is more than enough, and that CPU should still be good for another year or two. If you were really short on funds, buying a GTX 1050/1050ti would be pretty decent for some light 1080p gaming. A 1060 would be optimal, and would give you some great performance. Really, it's up to what you want.
As said above if you want an even cheaper option a 1050 Ti is a decent choice. I would choose from one of these 2:
RX 580: https://www.newegg.com/Product/Product.aspx?Item=N82E16814125964&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
1050 Ti: https://www.newegg.com/Product/Product.aspx?Item=N82E16814487290&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Actually if you have Amazon Prime here is an even better deal on a 1050 Ti 4GB https://slickdeals.net/f/10130252-gigabyte-geforce-gtx-1050-ti-4gb-graphic-card-gv-n105td5-4gd-106-after-10-mir-fs-prime-members
Another even cheaper deal, only 2GB model however:
1050 Ti 2GB https://slickdeals.net/f/10132136-msi-geforce-gtx-1050-2gb-69-24ar-jet-com-spring15-promo
My budget is can be substantial. I want to do all the upgrades now so my computer will last for a while. I was thinking of a GeForce 1060 or 1070 for the gpu and an i5 or i7 for cpu. I would like to upgrade to DDR4 ram too. Could another option be getting an unlocked i5 and one of those Corsair closed loop systems to cool it? I mainly need recommendations r a good intel cpu mobo combo as in the past I am mostly familiar with AMD. I do other things than games and would like something to last be another couple years. Also do you think its possible to sell the old parts on ebay? Can they still be worth anything?
Budget between 500 to 700 hundred? I'm willing to pay more more if you provide a good build.
