Advice for possible upgrades
Thouroboros
31
Hi there, I was wondering if anyone would have suggestions for upgrades:
Core: FX-6300 @ 3.5GHz
Cooler: H80i
Motherboard: ASUS M5A78L-MLX
RAM: 8GB @ 1333MHz
GPU: Gigabyte R9-280X
PSU: Corsair AX 760
HDD: Seagate 2TB
(Other stuff:)
Case: Storm Scout II
Monitor: Samsung B2330
Mainly looking to be able to play games on max with no frame rate drops. The 280X is good but not able to max things out.
Thanks!! :)
I would overclock your CPU to 4.4-4.5 would get you an fps boost. 280x is still good. If you overclocked look into a GTX 970, would have no trouble maxing then.
Like I said though, I wouldn't stick the 970 with a stock speed 6300.
I will definitely OC the FX-6300. On the topic of OC'ing, how would my performance look if I OC'd the 280X? I'd prefer not to spend money when its avoidable, of course. I might need a new motherboard ... 😛
you may get 10ish fps improvement i think you have to oc a card pretty hard to get quite a bit of fps improvement unless you get it clocked really high then you will see a improvement
