Advice for RAM for GA-990FXA-D3
GillesR
Commendable
May 24, 2016
6
Hello,
I would like expand my RAM on my pc: I notice that 8gig is not enough anymore to run the newest games smoothly. I am a bit overwhelmed by all the possibilities and feel like I don't know enough on the subject to make a solid choice.
Motherboard: GA-990FXA-D3
Processor: AMDFX-4100 quad core
RAM: 8 gig of DDR3 (takes up 2 slots, which means I have 2 free slots).
Your thoughts? 🙂
MERGED QUESTION
Question from GillesR : "Your advice for extra RAM please."
mr kagoris, i have a gtx 970 on a asus p6t motherboard and core i7 920, and 6 gb ddr3 ram. is my cpu the bottleneck as well? which cpu can my motherboard support or should i just get a new motherboard as well?
I'd say you should upgrade to Skylake. An i5 6500 with a H110/H170/B150 motherboard and 8GB of DDR4 RAM would work fine.
I don't see the 8350 or 8370 anywhere in that list.
Hey guys,
Thanks for your responses.
@ CountMike: thanks for searching, but that website does not ship to my specific country.
@ Mr Kagouris: thanks for your remark about the CPU. Indeed, I was planning on changing it.
I've done a lot of reading and conclude that my hardware is 'passed it', so to catch up I would need a new CPU and a new Graphics card.
At this moment, I was thinking about a NVIDIA GeForce GTX 970.
Apparantly, the graphics card I currently have only has 1 gig over dedicated memory. I think this is the cause for lag, and not the RAM per se. Can someone confirm this?
I've read that it needs a double slot, which is provided by my motherboard.
I'm afraid my CPU won't be able to make the most of the Geforce GTX 970 though... Wat do you advise oh mighty internetmen of wisdom?
MB version is marked at lower left corner and BIOS version can be found by CPU-z for instance. FX 8320 would be a good match for GTX 970. Amount of VRAM can be important with stronger card but on bottom end cards would do nothing for performance. That GPU could easily use even 4GB and what they refer to as "Double slot" is that it takes space of two single cards but it's installed in one PCIe x16 slot.
On that MB that means that it would cover that PCIe x1 slot and render it unusable, that's all.
Another concern would be PSU, if it has enough power for GTX.
All that would be cheapest way to get desirable performance, for anything better you should be looking at Intel and most new parts.
Thanks!
PSU is okay, the card requires at least 500w and I can provide that.
I presume the GTX 980 will work with my AMDFX 4100 (even though not at full potential)? So I can upgrade the CPU later when I have saved up some more money?
I'd go a;long with Mr Kagouris on the CPU support, yes it's a 990 chipset, but it a 4+1 power phase design and lacks cooling of the VRM, many boards like this didn't get updated support for the upper end FX chips, and the list looks as if it's been updated they added the 6300. A 980 would be bottlenecked by your current CPU. If you, I'd either wait and see if Zen delivers when released or move to Intel. Your mobo isn't really up to a upgrade (a worthwhile upgrade anyway) and current CPU isn't really up to a higher end GPU
