Advice for upgrade
gimpchop
62
Hi all jus recently purchaced a r9-270 and love it. Im now looking for a upgrade on my cpu. I currently have a asus m4a79 deluxe mobo 8gb ram and aphemon ll x4 955 be overclocked to 3.6. I would like to upgrade my cpu only but realize i may need to go further i just wan to get the best from my gpu with no bottlenecks. Budget is only £150. Thanks.
Hi just a quick up date I made my purchase and went with
msi z97 gaming3 mono
Intel g3258
8gb gskill ripjaw
evo 212 fan
total cost 210 gbp
Overall I'm very happy with my rig I got a stable overclock of 4.6 ghz. It's a snappy little pc with plenty of room for upgrades. My only gripe is that fifa15 no longer runs smooth but games like far cry 4 and assassins creed work 100% better go figure. A big thanks to all for the advice.
PCPartPicker part list: http://uk.pcpartpicker.com/p/pfq8P6
Price breakdown by merchant: http://uk.pcpartpicker.com/p/pfq8P6/by_merchant/
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor (£87.86 @ Ebuyer)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard (£60.34 @ Amazon UK)
Total: £148.20
Generated by PCPartPicker 2015-03-10 08:26 GMT+0000
Picked out a better motherboard and a budget CPU for you, both under your budget limit.
PCPartPicker part list: http://uk.pcpartpicker.com/p/ZhVQD3
Price breakdown by merchant: http://uk.pcpartpicker.com/p/ZhVQD3/by_merchant/
CPU: AMD FX-8320 3.5GHz 8-Core Processor (£111.20 @ Ebuyer)
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard (£65.14 @ CCL Computers)
Total: £176.34
Generated by PCPartPicker 2015-03-10 08:40 GMT+0000
Little overbudged but a nice cpu and mobo
Yes the dual core that I picked out is much more better than the quad core as that CPU is a bit older and will bottleneck the 270 in a few games. For RAM, are you able/willing to increase your budget a little?
You could do this. But just beware that you may require a BIOS update.
PCPartPicker part list: http://uk.pcpartpicker.com/p/8XgWBm
Price breakdown by merchant: http://uk.pcpartpicker.com/p/8XgWBm/by_merchant/
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor (£51.99 @ Ebuyer)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard (£33.72 @ CCL Computers)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory (£54.00 @ Amazon UK)
Total: £139.71
Generated by PCPartPicker 2015-03-10 18:22 GMT+0000
The ram is worth it, but that CPU and motherboard definitely aren't. @OP I would suggest saving up an extra ~£50 and going with learningbitbybit's first suggestion, plus the ram he mentioned in the quote
The general quality of it isn't very good (the mobo), although it would be silly to expect otherwise from a £30 board. As for the ram, while it is okay, it is one stick of 4gb, which isn't really enough for gaming.
A BIOS update isn't too hard though; just ensure that you are connected to the internet.
Hi really interested in the I3 rig just have a few qs
1) can I upgrade the cpu in the future say to a I5 or i7?
2)do u get a cpu fan with the cpu cos I ca t afford a fan aswell?
3) I only havve a 500w psi is tha sufficient for this rig?
Thanks.
If you choose to go with the i3 setup I picked out for you:
1. Yes, that board is compatible with i5, i7 CPUs but it can't overclock so consider getting a Z board if you plan on overclocking in the future
2.You only really need a CPU cooler if you are planning to overclock
3.Yes, the 500w PSU will work fine
