I'm sure you get these questions all the time so I apologize in advance!
I've been looking to upgrade the computer a friend of mine pretty much put together for me 4-5 years back but am not really sure where I'd get the most bang for my buck. Or if the motherboard needs to be upgraded to really make use of newer equipment. Or if I should just stick it out and wait for something newer etc... you get the picture. I utilize the PC primarily for gaming and work (which is not computing heavy at all).
I know I should probably get a SSD first but I'm kind of hoping that good quality 1Tb versions will be dropping in price sometime soon, that way I don't have to worry too much about having the two.
My monitor was also purchased around the same time as the computer was built but it supports the current video card quite nicely (as far as I can tell.)
Here are the specs:
MSI Z97-G55 SLI (MS-7921)
PSU - 750W Thermaltake SP750
i5 4690K 3.50GHz
DDR3 1866? 8Gb x2
GTX 770 4Gb
1Tb HD
Thank you all for your advice, let me know if you need any other information!
EDIT: Budget - I'm not really looking to spend a LOT of money, but the budget is kind of open right now. I'd like to get an idea of what you all think is necessary/a good idea and go from there.
PSU- 750W Thermaltake SP750
Thanks!
Here are the specs:
i5 4690K 3.50GHz
DDR3 1866? 8Gb x2
GTX 770 4Gb
1Tb HD
Thanks!
