[SOLVED] Advice for upgrading my gaming system
Dec 13, 2018
4
Hi guys,
I would like to upgrade my current system because I would like some better performance while playing Battlefield 5. Currently I play at 60-80 FPS on low.
Approximate Purchase Date: Next month
Budget Range: +/- 500 euro
System Usage: Gaming (mostly BF5)
Monitor: Using a 60Hz 1080P atm, want to upgrade next year to a 144HZ 1080P
Parts to Upgrade: CPU/MOBO
Overclocking: Maybe
My current setup:
CPU: AMD Ryzen 5 1500x
MOBO: MSI B350M Mortar (with the latest BIOS)
RAM: Corsair Vengeance LPX CMK 16GX4 M2A 2400 C16 (2x8GB)
GPU: Gigabyte GTX 1060 6GB OC
DISKS: 1x 250GB SSD, 2x 125GB SSD, 1x 1TB HDD
I searched online and came up with 4 options:
Option 1
CPU: AMD Ryzen 5 2600x
MOBO: ASRock B450M Pro4
Option 2
CPU: AMD Ryzen 7 2700x
Option 3
CPU: Intel i5 8600k
MOBO: MSI Z370M Mortar
Option 4
CPU: Intel i5 9600k
What is you opinion or what do you give as an advice?
Thank you in advance for the effort!
Dec 13, 2018
4
Dont have any experience with overclocking.
Does the RAM makes that big of an upgrade?
logainofhades
Ryzen is very ram sensitive, and needs fast ram to get the most out of it. Your CPU should be capable of higher settings, than what you are running at, after looking at some benchmarks. Are your drivers up to date? Have you looked at temps at all?
https://www.techspot.com/review/1746-battlefield-5-gpu-performance/
https://www.techspot.com/review/1754-battlefield-5-cpu-multiplayer-bench/
The 2400g would be pretty even with your 1500x, at like clock speeds, and gets similar framerates with a much faster GPU, as what BF5 gets with a faster CPU, and the same GPU you have. Your system is pretty balanced.
Dec 13, 2018
4
Sounds good, do you have any recommendation for me?
i found myselfe Corsair DDR4 Vengeance LPX 2x8GB 3200 C16. Its the same RAM that i allready have but mutch faster
logainofhades
This kit is fairly inexpensive.
Memory: Team - Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory ($110.88 @ OutletPC)
Total: $110.88
Generated by PCPartPicker 2018-12-13 14:42 EST-0500
Just as a side note, if you still want to upgrade your CPU, your current ram is fine, with an Intel build. Intel's architecture isn't as ram sensitive, as Ryzen is. If you want to stay AMD, no need for a new board, as stated above. With the latest bios, you have support for a 2600/2700.
