Hlsgsz :
Cortez-sennin :
Hlsgsz :
Cortez-sennin :
Hlsgsz :
Cortez-sennin :
Hlsgsz :
See if you can find one of these:
ASRock B150M Pro4V
ASRock B150M Pro4/Hyper
(not the ASRock B150M Pro4 you listed as it lacks an m.2 port)
Gigabyte GA-H170-GAMING 3
ASRock H170M Pro4S
MSI B150M BAZOOKA PLUS
MSI B150 PC Mate
Gigabyte GA-H170M-D3H
ASRock H170 Pro4
Gigabyte GA-H170-D3H
Unfortunately any H170 MB costs a million here so I will have to go for a B150 MB.
I can find ASRock B150M Pro4V and MSI B150M BAZOOKA PLUS here but why should I choose them instead of MORTAR?
They have an M.2 slot for when NVMe SSDs come down in price.
Not really interested in M.2)
Also - they have already come down in price)
For example the M.2 version of SSD drive I've bought for my build costs only 3$ more on amazon)))
That woudl be a
SATA M.2 drive that offers no performance advantage whatsoever. I'm talking about
PCIE x4 NVMe SSD which cost about double per GB. Once those come down in price, i pretty much guarantee that you
will be wanting one
You asked for a good MB, i'm telling you what you should get feature wise with an eyes forward attitude. If you carry no interest in M.2, just get teh cheapest MB you can find. H110. They all perform teh same anyway.
I apologize - my bad concerning NVMe M.2. It is 1:10 AM here so I am not very attentive)
Concerning H110 - my personal position is that this chipset more suits i3 CPUs then i5. I wouldn't be able to get a full i5-6500 and gtx 1060 potentials on H110
No worries. You are dead wrong on this. there are several differences between teh chips, but, the most practical would be that the h110 only supports 2 RAM slots. Performance-wise, there's no difference whatsoever.
This article will set you straight
http://www.tomshardware.co.uk/msi-h110m-pro-d-lga-1151-micro-atx-motherboard,review-33661.html
Are you sure about that man? As far as I know - H110 appears to be really slower in terms of performance. It has fewer and slower PCIe lanes and uses the older DMI 2.0 revision.
You may check this article to set you straight)
https://www.pugetsystems.com/labs/articles/Z170-H170-H110-B170-Q150-Q170---What-is-the-Difference-635/
(check comparison table and "ctrl+f" phrase "In addition to having"
Also the benchmarks on motherboardbenchmark.net should be based on something, isn't it? They couldn't be based on slots and I/O connectors only.
