Advice needed: <= $1000 gaming build (thanks in advance for your help)
ScreamerOfSorts
21
Approximate Purchase Date: This week, if possible
Budget Range: <= $1000 USD, after rebates
System Usage from Most to Least Important: Gaming, web surfing
Parts Not Required: Keyboard and speakers
Preferred Website(s) for Parts: http://www.newegg.com
Country of Origin: USA
Parts Preferences: 2nd gen core i, everything else upon recommendation :)
Overclocking: Maybe
SLI or Crossfire: Maybe
Monitor Resolution: Depends on what's in the final build
Additional Comments: Most of this build was taken from other posts, but I want to make sure everything is compatible, and see if there are any lower-cost alternatives. Thanks in advance
FINAL BUILD!!!! :hello:
CPU / Mobo: (suggestion from gkay09)
Core i5-2500K & MSI P67A-G45 (B3)
$332.98 - $20 MIR = $312.98
GPU: (suggestion from gkay09)
EVGA GTX 560 Ti 1GB
$239.99 - $25 MIR = $214.99
HDD / Disc Drive:
Seagate Barracuda 500GB 7200 RPM & LG DVD±RW SuperMulti Drive
$52.48
RAM: (suggestion from gkay09)
Crucial 8GB (2 x 4GB) 240-Pin SDRAM DDR3 1333 (PC3 10600)
$49.99
PSU:
Antec HCG-750W
$94.99 - $25 MIR = $69.99
Case:
Antec 300 Illusion
$59.99 - $10 MIR = $49.99
Monitor:
Hanspree 21.5'' 1920x1080
$119.99
Mouse:
Rosewill RM-2400L
$9.99
OS:
Windows 7 Home Premium 64-bit - OEM
$99.99
TOTAL: $985.39
Thanks so much for your help!
^ Good parts,... Some suggestions -
Get the G45, its just few $$ more, and and has USB3.0 bracket included,...
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.660241
CASE - A good deal on the new Lian-Li case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112322
Monitor -
http://www.buy.com/prod/asus-vh236h-23-widescreen-hd-lcd-monitor-1920x1080-20000-1-2ms-hdmi/q/loc/101/210917291.html
RAM - Why not 8GB, its pretty cheap these days,...
It is one of most underrated RAM,...This can easily run @1600Mhz without any issues,...
Crucial 8GB DDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148347
Monitor -
Crucial 8GB DDR3
A better mouse, IMO, for $40:
http://www.newegg.com/Product/Product.aspx?Item=N82E16826153056
That case seems too expensive, but cases go by taste, so whatever. I put $80 into my Dragon Slayer.
If you've got a couple extra bucks (you do, 33 of them) you can get a nicer GPU. If you put in $20 over that, you're at a cheap 560 Ti for $220 (http://www.newegg.com/Product/Product.aspx?Item=N82E16814261100), which would almost justify the 2500K. The 6870 doesn't, really.
Thanks for the suggestions! I have a Lian-Li case myself, and love the tool-less design and the steel (feels heavy and durable). I've added the ram and mobo changes, though I'm not sure about the monitor yet. I'm building this for my brother, and he wanted to get everything from one place if possible, but I'll see what he thinks.
Thanks again!
Thanks for the suggestions! I defaulted to the logitech because I have a G700 myself, but I've heard a lot of good things about RAZER gaming mice. It looks like I have a little to spend on a graphics card, so I'll check out the 560 Ti. Is that compatible with the Mobo that gkay09 linked? Would you recommend anything better with ~$200 to play with?
Thanks much!
I like the suggestion, but my bro wanted a full-size HDMI slot on the card.
What do you think of DIY as a brand? I saw this card, which is the same price after rebate:
http://www.newegg.com/Product/Product.aspx?Item=14-133-380&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=2
Will this be compatible with the motherboard? Not exactly sure what I have to look at here :\
Thanks!
