Build Advice Advice on +-€1500 iGPU build (will add on GPU when funds allow)
Jul 26, 2022
I haven't built a PC for over 10 years and due to life happening I have a small window of opportunity to build one last system.
The basic premise is to build a good looking, durable iGPU build for +-€1500 which can do a little gaming. And can be upgraded with a graphics card later this year to do proper gaming.
I have a basic idea for the build, mainly would like some of you to go over it and see if I did anything stupid.
Approximate Purchase Date: 27-31 July
Budget Range: +-€1500
System Usage from Most to Least Important: Gaming, Home Entertainment, Surfing, Office usage
Are you buying a monitor: No
Parts to Upgrade: none starting from scratch
Do you need to buy OS: Yes, however not included in budget.
Preferred Website(s) for Parts: If it ships to Holland I can use it, I can find my own parts though.
Parts Preferences:
I'll list my basic idea here:
ComponentNamePrice
CPUIntel I7-12700k€ 422.90
MotherboardMSI MPG Z690 EDGE WIFI DDR4€319.-
MemoryCorsair Vengeance LPX CMK32GX4M2D3600C18€129.90
StorageSamsung 980 1TB€91.31
PSUXPG Core Reactor 850W€124.90
CaseLian Li O11 Dynamic EVO€139.90
AiO CPUNZXT Kraken X73 RGB€189.90
For fans 5x Arctic P12 for €25.71
Totals for: €1443.52
SLI or Crossfire: No
Your Monitor Resolution: 2560x1440 & 4096x2080
Additional Comments:
I plan on upgrading with an RTX 3080 (TI).
Would like the system to be able to output 4K graphics after the upgrade.
My main question is if the build is balanced, secondary question being of it will handle 4K with RTX3080 added on.
All advice is welcome!
Thank you in advance!
There is not a lot anymore in terms of OC and/or features with unlocked CPUs and Z690 boards compared to the locked processors and B660 chipsets. Whatever little gain you get from overclocking Intel these days, is not worth the extra time, money or effort. The locked processors are pretty close to the unlocked ones and can boost almost to similar clocks.
This will give you similar performance while saving some money...
PCPartPicker Part List
Type|Item|Price
CPU | Intel Core i7-12700 2.1 GHz 12-Core Processor | €392.95 @ Azerty
CPU Cooler | ARCTIC Freezer 34 eSports DUO CPU Cooler | €45.50 @ Amazon Netherlands
Motherboard | Asus TUF GAMING B660-PLUS WIFI D4 ATX LGA1700 Motherboard | €202.95 @ Azerty
Memory | Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory | €129.90 @ Amazon Netherlands
Storage | Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive | €119.90 @ Azerty
Case | Lian Li Lancool II Mesh ATX Mid Tower Case | €100.37 @ Amazon Netherlands
Power Supply | Corsair RMx (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply | €139.00 @ Amazon Netherlands
| Prices include shipping, taxes, rebates, and discounts |
| Total | €1130.57
| Generated by PCPartPicker 2022-07-26 14:13 CEST+0200 |
You have the budget, you could get a GPU now, something like a 6600xt, and enjoy some gaming now. I would not get the 3080ti though. The 3080 12gb, or a 6800xt/6900xt, is a far better buy.
CPU: Intel Core i7-12700 2.1 GHz 12-Core Processor (€392.95 @ Azerty)
CPU Cooler: Deepcool AS500 70.81 CFM CPU Cooler (€53.75 @ Amazon Netherlands)
Motherboard: Gigabyte B660 GAMING X AX DDR4 ATX LGA1700 Motherboard (€182.95 @ Megekko)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory (€114.90 @ Amazon Netherlands)
Storage: Crucial P3 Plus 1 TB M.2-2280 NVME Solid State Drive (€121.11 @ Amazon Netherlands)
Case: Lian Li LANCOOL 215 ATX Mid Tower Case (€93.85 @ Megekko)
Power Supply: SeaSonic FOCUS GX 850 W 80+ Gold Certified Fully Modular ATX Power Supply (€108.85 @ Megekko)
Total: €1068.36
Generated by PCPartPicker 2022-07-26 14:54 CEST+0200
