MERGED QUESTION
Question from dammy222 : "Advice on a build upgrade with AMD Ryzen 7"
Hello,
I'm planning to upgrade my build from 2013 as I start using my desktop again. My build currently uses i5-4670K and no external GPU. I use my computer for mostly software development (including data processing, image processing, etc). I also use it for some 3D CAD (Autodesk/Blender) and image editing with GIMP. Would like to keep this upgrade below $500 and not need to upgrade CPU/Mobo anytime soon.
Here are the parts I plan to REUSE from the current build:
Case (Micro ATX):
https://www.newegg.com/Product/Product.aspx?Item=N82E16811147023
CD Drive:
https://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
WIFI:
https://www.newegg.com/Product/Product.aspx?Item=N82E16833704162
PSU (Corsair CX430M):
https://www.newegg.com/Product/Product.aspx?Item=N82E16817139049
SSD_1:
https://www.newegg.com/Product/Product.aspx?Item=N82E16820147188
SSD_2:
https://www.amazon.com/gp/product/B00A1ZTZNM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Here are the NEW parts I am considering:
CPU (Ryzen 7 2700):
https://www.newegg.com/Product/Product.aspx?Item=N82E16819113498&ignorebbr=1
MOBO:
https://www.newegg.com/Product/Product.aspx?Item=N82E16813157843&ignorebbr=1
Graphics:
https://www.newegg.com/Product/Product.aspx?Item=1FT-001K-00003&ignorebbr=1
RAM:
https://www.newegg.com/Product/Product.aspx?Item=N82E16820231886&ignorebbr=1
Note for GPU: I think the most demanding task for the GPU will be my 3D CAD program. My laptop has a GeForce 940MX with 2GB and that seems to be good enough (for the most part) so hoping to get at least that level of performance with this build. I know for sure the integrated GPU in the i5-4670K is not good enough.
Note for CPU: I'll probably be okay with a Ryzen 5 but 2 more cores for $50 extra seems like a good deal and is more future proof.
Will this combo work well? Would appreciate any advice. Thanks
