Advice on a Ryzen system build
Tarashev91
So i am looking to build a new Ryzen based system.
I all be using my current GPU with the idea of upgrading later on.
Sapphire Vapor-X R9 280X
With a Seasonic S12II 620W Bronze 80 Plus PSU
And i am thinking of buying the following hardware:
CPU: AMD Ryzen 5 1600 six-core (3.2/3.6GHz, 3MB L2/16MB L3 Cache, AM4)
Motherboard: MSI X370 GAMING PLUS, X370, AM4, DDR4, PCI-E(DVI,HDMI)(CF&SLI), 6x SATA 6Gb/s, 1x M.2 socket, 10x USB 3.1, 6x USB 2.0, ATX
RAM: 16GB (2x8GB) DDR4 3200MHz, Corsair Vengeance LPX CMK16GX4M2B3200C16, 1.2V
STORAGE: SSD 250GB Samsung 850 EVO
1TB WD Caviar® Blue™, SATA 6Gb/s, 7200rpm, 64MB, 3.5"
WiFi: TP-Link TL-WN881ND, 300Mbps MIMO Wireless-N PCI-Е Adapter
Case: Zalman Z9 NEO Silver/Black edition.
Any advice or correction on my thoughts are wellcome. Good or bad.
Thanks for the advice. Will these fair better 16GB (2x8GB) DDR4 3000MHz, Team Group Delta Red, TDTRD416G3000HC16CDC01, 1.35V??
I haven't heard this. It has nothing to do with the RAM brand it has everything to do with RAM speed. You should get nothing less than DDR4-3200 at the moment.
I have a 1700 with the Trident Z. I can run the sticks fine at 2933, but at 3200 i need to manually adjust voltages or they wont boot out of the box at 3200
Yeah I have a pretty similar setup and I can use Corsair DDR4 on my Asrock Taichi with no problem. Also the Vengeance is listed in Gigabyte's QVL for their Ryzen motherboards specifically. So I think this must be misinformation coming from store reviews.
That is completely incorrect info. Vengeance works perfectly fine. In fact I have an 1800x build running Vengeance LED ram at 3200 mhz. At the initial release G-skill Trident Z was preferred because most systems needed Samsung B die to run at full speed. That has long been corrected.
The Corsair memory is better don't buy the Team Group.
