Hi!
I'm building a new pc with the following specs:
i5 4690k CPU (planning to OC)
MSI Gaming 5 Mobo
Corsair Vengeance 8GB RAM
550W PSU
Gigabyte G1 Geforce GTX 970
Hyper 212 Evo cooler
Three questions:
1. I'm thinking of using an Antec GX300 case. Will the Evo 212 cooler fit in the case? Or should I play it safe with the GX500?
2. Is my power supply sufficient for the build? Will over clocking affect this?
3. I will have 4 fans installed on the case (1 x 140mm, 3 x 120mm) Should this be sufficient cooling?
Thank you so much for your help!
MSI Gaming 5 Mobo
550W PSU
Three questions:
