[SOLVED] Advice on Build
TheNoobGamer
48
Hi guys, using PCCASEGEAR to build a PC for a friend here, just looking for a bit of advice on the build.
View: https://imgur.com/a/pqrv2RT
He would like to keep the price roughly around the same point +/-$75, also he is using the customisable prebuilt section so not too much of a change is possible.
Just wants to confirm that the parts are definitely compatible (even though they should be) and whether are any alternatives that are better). He is rather cautious about this before spending over $2000.
Appreciate all the help given, thank you.
You can get more for your money doing this:
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($319.00 @ Centre Com)
CPU Cooler: ARCTIC Freezer 34 eSports DUO CPU Cooler ($70.84 @ Amazon Australia)
Motherboard: Asus ROG STRIX B550-F GAMING (WI-FI) ATX AM4 Motherboard ($295.00 @ Skycomp Technology)
Memory: Team T-Force Delta RGB 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($176.00 @ Newegg Australia)
Storage: Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive ($94.80 @ Device Deal)
Storage: Mushkin Pilot-E 2 TB M.2-2280 NVME Solid State Drive ($367.40 @ Newegg Australia)
Video Card:...
Hello friend,
For a moment I thought "christ thats expensive" but I realised you're probably Aussie since your using PCCASEGEAR.
I know a friend that uses a Ryzen 5 with a 2060 and it runs great. I dont think that should bottleneck either. You've pretty much covered all over bases and looks like a pretty great build in my opinion.
George
Hello friend,
George
u can check here
Video Card: Gigabyte GeForce RTX 2060 SUPER 8 GB WINDFORCE OC Video Card ($599.00 @ Computer Alliance)
Case: Phanteks Eclipse P300 ATX Mid Tower Case ($94.47 @ Amazon Australia)
Power Supply: Super Flower Leadex III Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($159.00 @ PCCaseGear)
Case Fan: Deepcool RF 120 56.5 CFM 120 mm Fan ($23.00 @ I-Tech)
Total: $2198.51
Generated by PCPartPicker 2020-10-21 01:18 AEDT+1100
Then you can use this guide to get legitimate Win 10 for much cheaper: https://www.tomshardware.com/reviews/get-windows-10-free-or-cheap,5717.html
u can check here
Bottleneck calculator sites are trash, and in no way accurate.
You definitely want to shop around, vs buying all from one place.
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor ($509.00 @ Centre Com)
CPU Cooler: Silverstone PF240-ARGB 94 CFM Liquid CPU Cooler ($129.00 @ Computer Alliance)
Motherboard: Gigabyte B550 AORUS ELITE ATX AM4 Motherboard ($229.00 @ Umart)
Memory: Crucial Ballistix RGB 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory ($147.60 @ Device Deal)
Storage: Silicon Power A60 1 TB M.2-2280 NVME Solid State Drive ($162.80 @ Newegg Australia)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive ($89.00 @ Computer Alliance)
Video Card: Gigabyte GeForce RTX 2070 SUPER 8 GB WINDFORCE OC 3X Video Card ($689.00 @ Centre Com)
Case: BitFenix Nova Mesh TG 4ARGB ATX Mid Tower Case ($119.00 @ Scorptec)
Power Supply: Antec Earthwatts Gold Pro 650 W 80+ Gold Certified Semi-modular ATX Power Supply ($129.00 @ Mwave Australia)
Total: $2203.40
Generated by PCPartPicker 2020-10-21 03:30 AEDT+1100
Video Card: MSI Radeon RX 5700 XT 8 GB EVOKE OC Video Card ($569.00 @ Centre Com)
Case: Fractal Design Meshify C ATX Mid Tower Case ($146.30 @ Newegg Australia)
Total: $2286.50
Generated by PCPartPicker 2020-10-21 07:22 AEDT+1100
