I want to build a pc with RTX 3050 and i am thinking about paring it with a i5-11400F. Should go with 11th gen or 12th gen. 12th gen would cost me ~90USD more and the cpu bending problem on 12th gen mobo also makes me worried.
Here in pakistan the upgarde path for AMD based PCs is very limited. Intel cpus and mobos are abundant. And i donot feel comfortable with AMDs PGA design and i have never built an AMD sys before. My budget is also very limited(meaning i cannot afford to bend the cpu pins or any other mishap)i'm in the AMD camp right now and don't see any reason to go with intel at the moment.
many will disagree for sure, but i see no reason to pay extra for the mobo/cooling etc for the intel system at this time. the performance is there for sure, but the total cost to me is not worth it when you can go Ryzen for less overall system cost.
just my worthless 2 cents thrown in![]()
Such is one of the costs of being an early adopter of a new platform. Unless you opt for an i9, the warping issue won't hit you very hard. They'll probably have it sorted out with the 13th gen boards. PROBABLY...the cpu bending problem on 12th gen mobo also makes me worried.
