Advice on Building
aal763
5
I was just wondering if all of these components will work together and particularly if everything will fit in the case I specify? Please let me know if I'm forgetting anything too or something that I probably need. I know nothing about building a computer and am going to have a friend build it for me.
1.) Intel Core i7-4790K Haswell Quad-Core 4.0GHz LGA 1150 Desktop Processor
2.) ZALMAN CNPS11X Performa 120mm Long Life Bearing V-Shaped Dual Heat Sink CPU Cooler
3.) ASRock Fatal1ty Z97 Killer LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
4.) CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model
5.) EVGA ACX Cooler 03G-P4-2784-KR G-SYNC Support GeForce GTX 780 Superclocked 3GB 384-Bit GDDR5 PCI Express 3.0 SLI Support Video Card
6.) Western Digital WD Blue WD10EZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive - OEM
7.) LG Internal Super Multi Drive SATA Model - GH24NSB0B
8.) Cooler Master HAF 912 - High Air Flow Mid Tower Computer Case
9.) Cooler Master Extreme Power Plus - 600W Power Supply
10.) ASUS VS239H-P Black 23" 5ms (GTG) HDMI Widescreen LED Monitor 250 cd/m2 ASCR 50,000,000:1, IPS Panel
11.) Intel 7260HMW IEEE 802.11AC, dual-band, 2x2 Wi-Fi plus Bluetooth 4.0 Mini PCI Express combo Adapter - 867 Mbps+300Mbps - Internal - OEM
12.) SABRENT CRW-UINB 68-in-1 USB 2.0 Internal Card Reader w/ USB 2.0 Port supports SDHC/VISTA
Thanks,
Rob
Yes that's a good case, the power supply was the only thing that stood out as an issue and the lack of an SSD seemed a bit of a shame on such a nice build.
Run away from that power supply, it is not a nice one! A build as nice as yours deserves better!! How about this one instead? http://pcpartpicker.com/part/evga-power-supply-110b20750vr
It's much, much better and isn't going to blow your budget (hopefully!)
Your build would be even nicer with an SSD, a 120Gb one would make Windows and other programs load super-fast and a 250Gb one would have room for even a few games which would make stuff like levels and maps load quickly.
Alright. I will add that power supply to my list. How about everything else? Is the case big enough for all of the components? I'm not looking to spend more than $1700 total(including OS & Monitor)
Thanks,
Rob
Yes absolutely. They usually come with kits so you can clone your old HDD onto the new SSD too, this is good as it saves you the hassle of reinstalling Windows
*Though I recommend you check as they don't all come with the kits!
Awesome! Thanks for all of your help!
Rob
