Question Advice on buying Razer Kraken X headset ?
Oct 16, 2021
Hello I want to buy The razer kraken x headset but i saw pictures on the internet that the headband cracks easily due to plastic build. If someone here has experience with the mentioned headset,can you tell me what is the experience and build quality ?
(Im buying it because of my budget)
hang-the-9
60,031
1,001
152,790
16,669
For that price all the headphones will be about equal, just don't push on the thing too much when using it. Most breaks are from too much force rather than just normal use. Finding a few cases where things broke is not a reason to avoid a product, there is nothing out there that if you look enough you won't find someone that hates it even if 99% of others are just fine.
