Advice on components
Ctdsoccer
Commendable
Aug 14, 2016
6
Want a state of the art gaming computer that I don't want to update for a while, also this is a little on the expensive side, any advice would be appreciated, I have been out of the game for 10 years.
Thanks.
Gaming Keyboard w/
Kontact Blue Switches and Programmable Blue LED Lighting [+0]
BLUETOOTH:None
CABLE:None
CARE1:Ultra Enhanced Packaging Solution - Protect Your Dream System
During Transit [+19]
CAS😛hanteks Eclipse P400 ATX Mid-Tower Gaming Case w/ USB 3.0,
Side-Panel Window + RGB 10 Color LED light Strip (Satin Black)
CASUPGRADE:None
CC:None
CD:None
CD2:None
COOLANT:None
CPU:Intel® Core™ Processor i7-6700K 4.00GHZ 8MB Intel Smart Cache
LGA1151 (Skylake)
CS_FAN:3X Corsair AIR Series AF120 Performance Edition 120MM High
Airflow Case Fans [+39]
DOCKINGSTATION:None
FA_HDD:None
FAN😛hanteks PH-TC12DX Series High Performance CPU Cooler U-Type Dual
Tower Heat-Sink with Dual PWM Premium Fans [+13] (Black Color
(PH-TC12DX_BK))
FLASHMEDIA:None
FREEBIE_CU:None
HD_M2PCIE:None
HD_M2SATA:None
HDD:240GB SanDisk Z410 SSD + 2TB SATA III Hard Drive Combo (Combo Drive)
HDD2:None
HEADSET:None
IUSB:Internal USB 3.0 4-Port Hub [+25]
KEYBOARD:None
MEMORY:32GB (16GBx2) DDR4/2800MHz Dual Channel Memory [+231] (ADATA XPG Z1)
MONITOR:None
MOPAD:Corsair Gaming MM200 Mouse Mat - Standard Edition PN:CH-9000079-WW [+14]
MOTHERBOARD:GIGABYTE GA-Z170XP-SLI ATX w/ USB 3.1, 3 PCIe x16, 2 PCIe
x1, 3 SATA Express, 6 SATA3, 1 Ultra M.2 [+5]
MOUSE:CyberpowerPC Standard 4000 DPI with Weight System Optical Gaming Mouse
NETWORK:Onboard Gigabit LAN Network
NOISEREDUCE1:Anti-Vibration Fan Mounts [+9]
OS:Windows 10 Home (64-bit Edition)
OVERCLOCK:No Overclocking
POWERSUPPLY:650 Watts - Corsair RMi Series RM650i 80 PLUS GOLD
Certified Fully Modular Ultra Quiet Power Supply [+99]
PRO_WIRING😛rofessional Wiring for All WIRING Inside The System
Chassis - Minimize Cable Exposure, Maximize Airflow in Your System
[+19]
RUSH:Standard Process Time: Ship within 7 to 12 Business Day
SECURITY:McAfee AntiVirus Plus (Factory Pre-Install [Digital Version])
SERVICE:STANDARD WARRANTY: 3-YEAR [3 Year Labor, 1 Year Parts] LIMITED
WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SLI_BRIDGE:None
SOUND:HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS:Eagle Arion ET-AR302-BK 6 Watts RMS 2.0 Black Soundstage Speakers [+19]
TEMP:None
TUNING:None
TVRC:None
UPS1:NuGiant Energy Saving Smart Surge - 8 Outlets w/ 5 Energy-Saving
Outlets auto ON/OFF based on your PC (31002) [+29]
USBHD:None
USBX:None
VIDEO:GeForce® GTX 1080 Founder's Edition 8GB GDDR5X (Pascal)[VR
Ready] [+418] (Single Card)
WNC:None
WTV:None
_PRICE🙁+2438)
Which things do you think will need usb 3.0 internally requiring the hub? The motherboard itself has 3x usb 3.0 ports on the rear of the board (back of the pc case) along with 2x 3.0 usb headers internally for connecting the front usb ports to for the case's front usb ports. That will give you usb 3.0 front and rear for connecting devices to. If you are looking at something that needs extra usb 3.0 ports I'm not downing it, just trying to save you from buying additional things that come with the motherboard to begin with.
The 1080 makes more sense if you're considering 1440p or 4k.
I think even 16gb will be plenty for current/future gaming as well as supporting heavy multitasking. I don't see any glaring mistakes, good cpu, graphics...
That seems a bit expensive. Are you comfortable enough assembling parts yourself if you bought the parts separately? Buying them individually and building your own I think would save quite a bit.
Do you have any parts already like a monitor or anything and if so what screen resolution and refresh rate? Ie, 60hz monitor at 1080p, 60hz 1440p, 144hz 1080p? The 1080 is a nice gpu for sure but I'm wondering since the pricing says +418. $418 more than what starting price because the gtx 1080 is a $650 gpu. $420 is more the price of a 1070 which is also a nice gpu and more balanced for 1080p or even 1440p.
Are you planning to get into VR? (I don't see a vr headset or anything). 32gb of ram is overkill for a gaming pc and you can save some money there going with 8gb or at most, 16gb for a gaming pc. Internal usb 3.0 hub for an extra $25 isn't needed unless you have some sort of special requirements.
Thanks for the very good advice, no monitor haven't decided if I want to get a 4K hence the gpu,
I have priced them out separately, not hugely comfortable assembling myself and huge believer in paying professionals to do their job
your are right on the ram definelty can go less on that, and upgrade later on if needed
Yes the gpu price was 699, +418 is off the base I customized
Really thinking future here and work off this base later down the road
I read some things require USB 3.0, but can probably get rid of it for my situation
I think even 16gb will be plenty for current/future gaming as well as supporting heavy multitasking. I don't see any glaring mistakes, good cpu, graphics card, quality power supply with enough power for the system. Nice case.
I see a bunch of little addons that add up, and are NOT required.
Ultra Enhanced Packaging Solution - $20
Mouse mat - $14
PRO_WIRING - $19
Fan mounts - $9
Internal 4 port hub - $25
That's about $100 in unnecessary goop.
And then we get to the legendary CyberPower assembly (non)quality.
http://www.tomshardware.com/answers/id-2990661/asap.html
http://www.tomshardware.com/answers/id-2933633/bottom-case-filters.html
Thanks yes I am getting rid of most of that, and also really considering assembling myself, I have been pricing out the main components and have found it just might be worth the time, but time is money as well and this is pretty convenient, even if there is some technical fault on their end
