Hi everybody,
I wish to change some of the essentials in my computer. Some I should be able to keep but you are welcome to comment.
The purpose of the new rig is heavy gaming. I am a coder but beginner and I have a laptop for that. As stated budget is $1000 flexible.
Power supply - CORSAIR CMPSU-650TX 650W Compatible with Core i7 Power Supply
https://www.newegg.com/Product/Product.aspx?item=N82E16817139005
HDD - Western Digital Caviar Black 750GB 3.5" SATA 3.0Gb/s Hard Drive -Bare Drive
https://www.newegg.com/Product/Product.aspx?item=N82E16822136283
Sound blaster Z series card and a basic large black case to hold it all. It currently houses a (broken)gtx970 so I believe it should have the space for anything else.
I need a CPU, water cooler(So I can overclock that CPU), GPU, SSD, RAM(16gb should do it right?) and motherboard.
I just started my search so I will be updating soon.
Thank you for any advice.
Regards,
Tropicop
Regards,
Tropicop
