Hello all
Having just returned my CPU to Intel for a replacement I i have also cleaned out my PC properly and noticed a fair amount of dust buildup since its last clean about 1 month ago.
Also I would like to ask what people think about my fan setup and if I should be using a fan(s) in the top of my case or not.
Here is a link to my case
http://www.kitguru.net/components/roald/cooler-master-cm-690-iii-case-review/
My seup is as follows:
Coolermaster CM 690 III case (with side window, therefore no provision for side fan)
EVGA Gold 850W PSU (G2)
Asus z97-a mobo
Sapphire X-vapour Radeon R9 290x (3 fans) 4GB (runs below 80 deg C in furmark tests with full AA enabled at 1440p)
Intel i5 4690k
Corsair Vengeance pro 2 x 8GB 1866 DDR3
Coolermaster hyper EVO 212 CPU cooler
SSD Samsung 840 Evo
2TB Seagate HDD (storage only)
I will probably OC my cpu a little, maybe upto 4.4 max depending on its capability and obviously enable XMP.
System often used for BF4 and other gaming
My fans are stock so one large 200mm fan at front, 1 rear exhalent fan, the 212 cpu fan cooler, and 1 extra Noctua PWM (120mm I think) fan located at the bottom squeezed into the space between the cpu and the drive bays.
the case has a dust filter underneath which is easy enough to remove and clean but I am not sure if I should also be using a dust filter in the top of the case since I have no fans located in the top of the case. the case did not come with a dust filter in the top so I suppose I would like to know what you guys think?
Should I get a large fan or perhaps 2 small fans for the top (exhalent?) or just a dust filter?
Is the bottom fan (inhalent) really of much use or should I relocate to top?
Many thanks for your help in advance!!
Asus z97-a mobo
Intel i5 4690k
SSD Samsung 840 Evo
