Hello all.
I just finished building a rig. It POSTed and is running great. BUT.
I bought antec 4 pin 120mm rgb f12 series fans. I installed 10 of them. some intake and some exhaust.
All fans are running but no RGB.
Connected all the fans to the provided splitters. then I connected them to the commander xt.
The fans also cam with 4 pin daisy chain cables. Connected all fans via 4 pin then the final 4 pin into the msi jrgb 4 pin.
No RGB.
I downloaded ICUE and MSI center and still nothing. Any advice would be great.
MSI pro b650-p wifi
7800x3d
7800xt
850 psu
32gb ddr5
https://www.amazon.com/Antec-120mm-Case-Packs-4-PIN/dp/B08JPYK876/ref=sr_1_3?crid=5TR1JFLL66UK&dib=eyJ2IjoiMSJ9.wff5s8wOaNsnn9DWUFWqf9iiKpDw6qZupElNfvamk1oz4z_zgcNMyilWWYQ7c845W3KzBpCuAuWAGFCrJRiiAUlzbLKj9FxDsKxlA2CdTOuNi7vpzQR3Ph3NrcPKrA73qNZ7wPddX-AQLdEt8EKeRBvN1dPXfDn8kJXTIzvC-7-IVERb4YEtE8GX7wc6Jn-kjGsZoSphignrT4JzCQnfjwnOh9rjQw99nyd2Wr43IpE.bLiJ-9Z0fWVeCIVyqiXc1bMzcZ9Xp3SIQFAm0c0p0h0&dib_tag=se&keywords=antec+case+fans+rgb&qid=1710122127&sprefix=antec+case+fans+rgb,aps,121&sr=8-3&th=1
Probably something simple that I am missing.
Thx
No RGB.
MSI pro b650-p wifi
7800x3d
7800xt
850 psu
32gb ddr5
Thx
