APPROXIMATE PURCHASE DATE: 1-2 Weeks
BUDGET RANGE: $1000-1250
PARTS NOT REQUIRED: Have a 500g internal but might throw in a WD 640g Caviar
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, watching movies, surfing the internet
PREFERRED WEBSITE(S) FOR PARTS: newegg.com, amazon.com
OVERCLOCKING: Maybe down the road
SLI OR CROSSFIRE: Maybe down the road
MONITOR RESOLUTION: 1920x1080
ADDITIONAL COMMENTS: Last computer I built was five years ago, an AMD 64 rig. Ended up dying about two years ago and I’ve been using my school laptop ever since. This thing is a piece of junk but I haven’t had the time to play games or anything so I lived with it. However, I’m done with school now and looking to build a computer so that I can game again and watch HD movies and what not. I’ve done a little research but I’m not exactly sure if my build is adequate or if there are better or cheaper parts out there. If anyone has any suggestions on items that can help push the price down without sacrificing quality or performance then they would be greatly appreciated. Not taking into MIRs or bundles, the price stands at $1234.90 right now.
Case: COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
Mobo: ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131365
GPU: EVGA 896-P3-1170-AR GeForce GTX 275 896MB 448-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130475
PSU: CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
CPU: Intel Core i7 920 Nehalem 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor – Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Ram : OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3G1600LV6GK - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227365
Heatsink: XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
Keyboard: Microsoft Comfort Curve Keyboard 2000 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16823109149
DVD - HP Black 22X DVD+R 12X DVD-RAM SATA 22X Multiformal DVD Writer - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16827140040
Thanks in advance.
Thanks in advance.
