Advice on first build?
DyingSoulja
4
I need some advice on this build. I am starting completely from scratch here, and this is my first time building a custom pc. I have a budget of roughly $1,500.00. I am just hoping that I am getting the most bang for my buck as far as the item selection and price.
http://pcpartpicker.com/user/Bravo562/saved/Vh2j4D
Any recommendations or advice would be very much appreciated.
About GPU: I have owned 2 MSI Twin Frozrs and loved them. I highly recommend MSI and since they have no negative reviews for 970 I'd recommend it. On further investigation I think the MSI is a better choice. Why? Quieter than the EVGA. Yes, that matters. And the cooler is great.
http://www.bit-tech.net/hardware/graphics/2014/09/19/nvidia-geforce-gtx-970-review/13
You could get a 750W PSU but I think building for a one GPU system is better, hence you don't need the extra wattage. If you need more then sell the old one and upgrade. Multiple GPUs is really best for 3 monitor gaming. Otherwise I'd build for a 1 GPU system.
Thank you very much, and yes I didn't mention that this was a gaming build. Other than the GPU, how does the rest of the build look?
I'd get a better GPU and a i5 instead. No need for i7 unless you do lots of video work.
This build will give you a better gaming experience: higher in game settings and higher fps.
Better RAM, better mobo for overclocking, and GPU that will smash all games at 1080p on Ultra all the time.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($229.97 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($28.98 @ OutletPC)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard ($137.99 @ NCIX US)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory ($81.98 @ OutletPC)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive ($79.98 @ OutletPC)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($82.98 @ OutletPC)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card ($339.99 @ NCIX US)
Case: Cooler Master Storm Enforcer ATX Mid Tower Case ($74.99 @ Newegg)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($79.99 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.98 @ OutletPC)
Operating System: Microsoft Windows 8.1 (32/64-bit) ($94.99 @ B&H)
Monitor: Asus VX238H-W 23.0" Monitor ($157.58 @ Newegg)
Wireless Network Adapter: Rosewill RNX-N250PCe 802.11b/g/n PCI-Express x1 Wi-Fi Adapter ($18.36 @ Amazon)
Keyboard: Cooler Master CM Storm Devastator Wired Gaming Keyboard w/Optical Mouse ($24.99 @ NCIX US)
Total: $1449.75
Would you want a PSU with a little more wattage?
