Master-Shake
I put a list of parts together and I am pretty sure they all go together and I know I want to Overclock. I have read up on it and think its brings good value. Here is the list of parts. Also I cannot afford duel core at the moment so please dont suggest it. My budget is 1200 including shipping
Aspire X-Plorer Case-$58.00
Antec TRUEPOWERII 550Watt PSU-$81.99
Sapphire x1800xt 256MB-$239.00
DFI Lanparty UT-$112.99
Opteron 146-$223.00
G.SKILL Extream Ram(2GB)-$171.99
Wester Digital 250GB HDD-$89.99
NEC 16X DVD±R DVD Burner-$34.79
XP PRO-$80.00(Get it from College)
Floppy, Arctic Silver 5, Mouse and Keyboard-$30.00
Does it all look good? I would like Some opinions and advice. I choose the opteron 146 over the 146 because of the 10 multi. And the RAM is PC4000 so that will give me a little headroom. I choose the MoBo cuz I heard it is the best OC'er. Also this hardware is going to be bought from NEWEGG and it says OEM but on the package contents its says it has SV & RCA Cable, HDTV Cable, VIVO Cable, Power Cable, DVI-CRT Adapter, Driver CD. Is that everything I need? Also it will still come with cooler on it right?
moparman390
206
One more thing. The PSU will come with hookups for floppy and DVD drive right? I just want to make sure I will miss NOTHING
Relax, of course the power supply will.
The video card will come with a cooler too.
I know what you said and I am going to suggest this anyway. Now as for your choice of the Opteron 146, I think it would be a wise investment to find a way to work one of these in your budget:
http://www.newegg.com/Product/Product.asp?Item=N82E16819103588
It's only about $100 more but it's Dual Core. Now it might not mean so much to you but by the time you go back to school in August you will be wishing you had bought the dual core because multi threaded games will be hitting the market pretty widely by then and they will really take advantage of these. Plus the stock cooler on the dual core chips is really nice (it's big, has an 80mm fan and four copper heat pipes), it will let you do some middle of the road overclocking. You won't need to buy another one unless you are doing high overclocking (over 400MHz+). The 146 comes with a really small cooler you will need to replace no matter what to overclock. You could spend $100 more now or about $300 more later to get a dual core. Plus buying a decent fan/heatsink for the 146 is going to be like $50, that's half the cost of an upgrade to a dual core. You could even get a 3800+ to save $30 bucks over the price of an Opteron, lots of people up here have OC'ed 3800+'s to some amazing levels. Even if you only do some mild overclocking at first until you can afford to add a bigger cooling system for the 3800+ it will still be worth it because you can always add that later.
http://www.newegg.com/Product/Product.asp?Item=N82E16819103562
I would also add some more fans. The case comes with 2x80mm fans but places for 3x80mm fans and 1x120mm fan. Pick up another 80mm fan and a 120mm fan. You can get both for like $10.
blueangel
113
I would consider getting a duel core processor, or a duel CPU motherboard, and then you could get a second CPU when the duel thread games come out. I have an Asus k8n-dl, and it has ok overclocking options. Also the 246 is only 169 at NewEgg, it is OEM, which is good, if you are looking to overclock. The board will be a bit more expensive, but the 2xx CPUs are a little cheaper, and you will be able to just add a second CPU later, you won’t have an old single core lying around when you upgrade. Plus you could go to a duel core CPU if you wanted later on. My preference would be 246, with duel CPU board.
http://www.newegg.com/Product/Product.asp?Item=N82E16819103613
