Advice on memory stick and mobo
kfronda26
95
Im trying to build a budget gaming pc:
Processor: AMD A8-5600K Trinity
Motherboard: Emaxx A55 FM2
Video: Radeon hd 6670 ddr3 1gb
Memory:2x4GB or 1x8gb DDR3 1333MHz/ 1600Mhz/ 18++Mhz
PSU: 600w
hd: 80gb
is this ok? can some one advice me on what memory stick to buy? also if the mobo is ok?
You want 2x4GB so you can use Dual Channel support.
Couple of comments - I've never heard of Enmaxx before, so they probably aren't a brand to go for. If you're using a dedicated GPU I'd suggest seeing if you can get a 7750. Little point in an APU if not using the iGPU, and hybrid crossfire is pretty hopeless.
The PSU is a component than can destroy everything else in your compute if you get a low-quality one, so I'd suggest someone like Seasonic, Corsair, XFX, Antec, PCP&C, plus some others.
Where on earth did you find an 80GB HDD?? Make sure it's SATA not PATA, and I expect you'll run out of space quite quickly.
kfronda26
95
thanks
kfronda26
95
on the gpu you mean this http://www.amd.com/us/products/desktop/graphics/7000/7750/Pages/radeon-7750.aspx ?????
Latest posts
