Is that for just the motherboard?
How much ram do you need.
Do you need wifi?
Some thoughts:
MATX motherboards are usually less expensive. The difference mainly is 4 vs. 7 expansion slots.
How many past the graphics slot will you plan on using?
I would go with a 500 series chipset. They are better evolutions of the 400 series and are really no more expensive. One advantage is that the B560 chips allow faster ram via overclocking.
Many will include wifi.
Here is a msi B560M for $130:
https://www.newegg.com/p/N82E16813144397?quicklink=true
If you want wifi, either add in a wifi card or look for included wifi
Intel does not depend on fast ram for performance.
This g.skil 3600 ram is one of the lowest priced 2 x 8gb kits...
