Advice on my first build
OptimusShr
6
Hello, I am planning on building myself a gaming rig and was hoping I could get some advice on my parts. I did some research and think I have made good choices but some other opinions wouldn't hurt.
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103649
MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128376
Hard Drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
Memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231207
Video Card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814125256
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817703016
Monitor: http://www.newegg.com/Product/Product.aspx?Item=N82E16824236053
Optical Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16827136133
Case=http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
OS: Vista Home premium
I think what I am most worried about is the video card but any other recommendations you may have would be excellent
tecmo34
Administrator
^+1... Your GPU is good depending on your resolution.
Your MOBO is a good budget board but leaves you no room to expand with Crossfire. I would recommend getting a MOBO with two PCIe x16 slots.
There are plenty of good 4870's that pump hot air out of the case . No point having that open style cooler IMO
if you dont use an lcd at its native resolution the image will suck . You are marginal in games with the nr of that monitor . If you want to stick with a 4870 then get a 22 inch with 1680 x 1050 res instead[ or buy a 4890 ]
This memory is better for a phenom and will give you a slight performance boost
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
dont buy vista
download the release candidate of windows 7 and use that , till the full version is released . Its free , but only download from microsoft
falkun
15
Try this build on:
CPU/Mobo combo:
i7 920
Gigabyte UD4P
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.203722
$525
GPU/Memory combo:
Sapphire 4890
OCZ Platinum DDR3 1600 6GB (3x2)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.197122
$298
Case/HDD combo:
Antec 300
WD 640GB Caviar Black
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.204205
$120
PSU:
Corsair 650w
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
$100
DVD Burner:
LITE-ON 22x DVD-R
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106282
$25
CPU Fan/Heatsink:
XIGMATEK Dark Knight
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
$40
Thermal Compound:
Arctic Silver 5
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
$9
Monitor:
ASUS 21.5" 2MS 1900x1080
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236051
$180
Price: $1,296.80, after MIR: $1206.80 (Not including shipping)
OptimusShr
6
That is a little over my budget ($1200) ALthough I will pick up the thermal compound. The case and HD combo could work though.
falkun
15
I still recommend the same monitor, Case/HDD combo, fan/heatsink, thermal compound, PSU, and DVD-R.
Swapping a few parts to stay in line with your budget...
Mobo:
MSI X58 Pro-E LGA 1366
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130226
$190
**EDIT:** Review for mobo justification:
http://www.bit-tech.net/hardware/motherboards/2009/03/12/msi-x58-pro-review/1
GPU/memory combo:
Sapphire 4870 1gb
OCZ Gold 6gb DDR3 1600 (3x2)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.197117
$248
CPU: I7 920 $280
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
The rest of the links are accurate from before.
Total:
$1,191.80, after MIR: $1,121.80 (excluding shipping)
If anyone finds better combo deals let the OP know please.
