Advice on my TOP PC-Build for $3000+
chromose-47
Commendable
Mar 22, 2016
18
Zdraviya Jelayu, Tom's Hardware!
Please have a look at my hypothetical build.
Is anything missing?
Is some component bad?
Can a get a better component? Is something too expensive for what it offers? Any way to reduce the price?
Will be waiting for your opinions,
Spasibo, tovarish
i dunno where you are from. where I live a 980ti is 700$, an extreme 4 is 150$, an evo 850 is 90, 780t is 190$ and noone take into consideration toshiba/hitachi hd and b2 psu, cryorig is 100$. i7-6700k is 360$, ddr4 2133mhz 16gb 80$ and 3000mhz 90$
what's the pro of having a 980ti, spending 1079$ on a 180$ monitor? you have same result and performance with a much cheaper gpu like r9 390 or also a sapphire nitro r9 380x
value ram has no heatsink, i 'd get kingston hyperx fury, corsair vengeance lpx, g.skill trident. unless you do editing at professional level you will never use 32gb of ram.
check if you can buy from authorized site just the license and product key for W10. In my country is legal and it cost only 25$, download the iso...
Why? Doesnt WD have a high failure rate?
you could wait and see what Nvidia and AMD are going to offer this summer about their new gpu generation. 980ti is overkill for that monitor, you would have same performances with a much cheaper r9 390/390x. Get an Asus mx299q if you want to enjoy it. 32gb of ram are completely useless, especially those "value" ram. Since you are getting an excellent mobo go for corsair vengeance ddr4 3000mhz cl15. that psu is not comparable with Evga'standard, go for the G2, and get a Seagate 1tb or WD blue 7200rpm
overpriced products anyway, that build shouldn't cost more than 1800€
Hi. Thanks for the reply.
Dont care about monitor - doesnt make sense to me buying such thing. Buying for gamedev. Lesser resolution = lesser resources needed.
What about them? Could you please explain your thought?
>advicing overpriced ram with 3000 mhz
How will the speed alter the performance? I was thinking it is useless.
>And Seagate 1tb
Ahaha. Are you serious? The shitties hdd ever possible? Did you jus really advised me that?
check if you can buy from authorized site just the license and product key for W10. In my country is legal and it cost only 25$, download the iso first from the site
Australia, mate. They have ebanuty prices on anything: cigarettes for 25/pack, train ticket 4 dollars cheapest, beer $4 a bottle.
>what's the pro of having a 980ti, spending 1079$ on a 150$ monitor? you have same result and performance with a much cheaper gpu like r9 390
How is that? Are talking about games or serious stuff? Try benchmarks - results will vary. The pro is I said - weak gpu wont be able to handle heavy projects in unreal engine doesnt matter which monitor.
Cheers for your answers, will go with "no value" ram.
Oh thanks mate. Seems that you saved me a lot of mpney 😀
