Advice on over clocking, heat sync and CPU/Mobo/ H100i
Troof2Troof
148
Hello,
I plan on getting a Corsair H100i (to use in a NZXT Phantom 410 Mid Tower). I'll have a Asus Sabertooth Z87 LGA 1150 and Intel Core i7-4770K.
I have two concerns.
1.) I'd like to over clock a little bit in the future, when I'm ready and have researched it more. Will this combo be cool for that? Nothing crazy.
2.) for the H100i, should I use their heat sync or get something else?
Thanks!
Hi, thanks for the response but I already knew that. I was just curious about OC the mobo and cpu and the whole heat sync thing
Thanks for that well written and informative response. I really appreciate it. My power supply is compatible with haswell, it's a cooler master silent pro gold 1000w. You're the second person to suggest arctic silver. Will it really be that much better than stock? Which arctic silver is good?
Awesome, thanks man! Is there a certain Arctic Silver to get? I see a few different kinds on Amazon.
Also, If you play Borderlands 2, hit me up on Steam. My name is BeevrSkweezr
Hi, thanks for all the info. I completed the build and it's running awesome. Just wanted to say thanks to everyone who helped me!
Intel Core i7-4770K (OC'd to 4.5Ghz, 1.20v)
Asus Sabertooth Z87
EVGA GeForce GTX780 SuperClocked w/EVGA ACX Cooler (Plan on SLI when price drops)
Crucial Ballistix Sport 16GB (8GBx2) DDR3 1600 MT/s (PC3-12800) CL9 @1.5V
NZXT Phantom 410 (140mm front intake, 120mm side intake, 120mm back exhaust)
Corsair H100i (2x 120mm fans on top as an exhaust)
Cooler Master Silent Pro Gold 1000W 80 PLUS Gold
Samsung 840 Pro Series 128GB SATA 6Gbps SSD (Windows)
Seagate Baracuda 1TB 7200RPM HDD (Games/Storage)
Crappy DVD Burner
