Hi community, I'm struggle to build my first PC with a tight budget of 500€ (600$, 400£), I understand that with this budget I won't achieve great things, but I need your advice to create something solid as much as possible. Playing modern games is what I want to do with this build.
I chosen some components but still I'm not sure if my choices are correct, so some advice would be appreciate it.
Case: ZALMAN ZM-T3 BLACK 30 € Amazon
PSU: XFX TS SERIES 550W PSU 62 € Newegg
CPU: INTEL CORE I5-4460 3.20GHZ LGA1150 - BOX 177 € Amazon
Motherboard: GIGABYTE GA-B85M-HD3 RETAIL 62 € Amazon OR MSI B85M-G43 RETAIL 74 € Newegg
VideoCard: MSI RADEON R7 240 2GD3 LP 2GB DDR3 PCI-E RETAIL 66 € Amazon
RAM: KINGSTON HX324C11SR/4 4GB 2400MHZ DDR3 XMP HYPERX SAVAGE 47 € Amazon
Some questions, what is better to have a powerhouse CPU or a good Video Card? or a middle solution, should I go for an Intel I3 with the budget I have, I read on the forums and elsewhere that 2 cores CPU's can not even launch some new games.
So guys what are your thoughts what can I change for better price/quality? The most important, will all those components work together?
Thank you for your help. people, I hope I didn't confuse you.
armoros.!
armoros.!
