Hello all,
I am about to build a PC primarily for a scientific application (EFIT calculations) which requires large amounts of memory and is sequential / single threaded. Since I was a bit out of it hardware wise, I’d very much welcome comments if anybody sees a significant pitfall to this build.
For the specific application setting, at least 128gb of ram is required. I don’t own the source code of the application, so changing the application is no option. Even if, I doubt reducing the required memory is possible without extending the computation time considerably.
The reasonable choice for this application would probably be to rent or buy an old server with enough ECC ram, however anything halfway close to what I would be willing to spend has very poor single thread performance. A very good offer for a Corsair Vengeance 128gb 2933Mhz kit (non-ECC) kind of made the decision for me to build a PC instead of buying/renting a server, which I can use also after finishing the calculation in a few months, mainly for video transcoding and gaming (given I add a better graphics card).
So far I only own the ram kit and am planning to add the other components to the build
- Memory: Corsair Vengeance 128gb 2933Mhz http://
- CPU: Intel I7-7820X http://
- Mainboard: Asus Prime x299-A http:// (undecided)
- Drives: HDD:8tb BarraCuda HDD ST8000DM004 http:// for storage,
SSD: Crucial MX300 CT525MX300SSD1http:// for OS, calculations etc.
- Power supply: be quiet! Pure Power 600 Watts http://
- Graphics card: Old Graphics card, most inexpensive solution I can find
The reason for choosing the I7-7820x and the 2066 Platform even tough the prices are somewhat eye-watering especially compared to the new AMD Ryzens is on the one hand the better single thread performance and the fact that I have only been able to test the application on intel systems. Choosing intel over AMD for stability reasons maybe a bit ironic because the Corssair Vengeance ram kit is advertised as to be used with AMD processors, however I hope they also work with a intel processor even if at a lower speed (please correct me if I’m wrong).
