I am currently using:
1) an Arris SB6190 Cable Modem connected to a 4-port Gigabit Switch.
2) The Switch has
a) A Samsung Smart TV is hardwired to the switch and
b) A Google WiFi that is used to directly connect a Ring Doorbell and several Ring Floodlight Cameras (Without the Ring Chime Pro Extenders) as well as the regular tablets, cell phones and computers.
Problem: My Google mesh WiFi gets knocked offline frequently.
a) Partly due to a Signal/Noise Ratio higher than most (The Cable Company is going to troubleshoot that) and
b) Partly due to a compatibility issue with Ring Products with the Google mesh WiFi (According to Google Technical support.
I am thinking to separate isolate the Ring Network like this:
Hard wired to the Switch:
a) Samsung Smart TV
b) Google WiFi for everything except the Ring products
c) A new Standard 802.11 ac dual band gigabit WiFi router connected to the Ring Chime Pro Network Extenders and the Cameras.
Question:
Will the Standard 802.11 ac router and the Google mesh WiFi co-exist without making another problem? Any thoughts from anyone setting up two home WiFi and Mesh WiFi in the same sandbox?
2) The Switch has
a) Samsung Smart TV
Question:
