I have an older external hard drive that around 100 video files that I am unable to transfer to my other drives.
I know it’s slowly dying and I want to save the files if I can.
When I try to copy or move the files to another drive everything is find until somewhere around 15-20% is copied and then Windows changes the time to transfer from couple minuets to an hour. It usually stops there and nothing is transferred.
I tried to check the drive for errors but it seemed to get stuck doing that. I tried to use Recoverit but that just found deleted files and didn’t seem to see the files I want.
Disk Management says is NTSF and healthy.
Any advice?
Any advice?
