hey everyone, doing a second build soon for my uncle. i just build my first gaming pc and everything went really awesome. with some help from you guys it was great. anyway i am building a pc for my uncle that he will be using for basically only home use, browsing, email, skype, documents, faxing, all that normal stuff. absolutely no gaming or anything of the sort. i am on a budget with it, so this is where i am at right now.
amd a8 6600k richland
motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813128659
256 samsung ssd. 840 pro or evo, havent decided yet, but one of the two
memory i havent decided yet, 2X 4gb sticks. something cheap, but efficient, prob 1600.
windows 8.1 os
psu, i want the corsair cx430m is that enough power for this build? im pretty sure it is, but wanted to check with you guys first!
thanks so much
windows 8.1 os
thanks so much
