Advice on Video Card and Power Supply needed
omniowner
Hello all,
I am wondering if..
This Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102837
and this power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341019
Will fit/work properly with my computer - Hp a6622f.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01564790&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN#
I have read about being careful about making things will fit and/or work together, and honestly I am a hardware noob! I am moderate computer user though, so I am not a complete noob I know a lot about computer related stuff but I have never installed a video card/power supply in a computer before.
Do you all think this will work?
And if so, do you think I could do it myself with a little effort?
Thanks in advance for responses!
Assuming that It is not a "slimline" PC then The new power supply is just a bit longer (35mm) than the old one, meaning that you can almost definitely put it in.
Wow thanks everyone for all the input! It appears I won't have a problem and I will be checking everyones links out now. Thanks again!
