Advice on what case to choose for Asus NCT-D Motherboard
macvwin
Hi all,
I've just purchased a Asus NTC-D Motherboard and im finding it hard to find a case for it. Its a server motherboard but can be used for desktop cumputing as well. And also I need help finding a PSU with a 24pin and 8 pin, as the motherboard is like that. So to round it up:
Need help, suggestions, directions, sites, on chosing a PC case that the motherboard would fit in and a PSU where to buy them and which one would you recommend.
Thank you very much, waiting for your help.
macvwin
thanks for your quick reply Helloworld_98, i google-d it and it looks pretty specious. i think i might just purchase it. Now as regards the PSU, if i purchase a 24/4pin PSU are there any adapters so it can fit into the motherboard with 8 pin CPU?
