Hi, I have been doing research for a while about how to connect my new gaiming pc to the internet. You see my room is too far away to run a cable to my pc so i thought a wireless adapter would work.
Apparently, there is very few ones that work with windows 7 64-bit. Every adapter I look at, some of the reviews say it is not compatible with windows 7 64-bit.
So I thought why not try an Ethernet bridge? There shouldn't be any compatibility issues with them.
The problem is I can't find any that seem stable for under $100.
So my question is if you guys have any suggestions for good Ethernet bridges
or
maybe i should get a wireless adapter after all
or
maybe I should bite the bullet and get a really long LAN cable.
or
or
