Question Advice overclocking 9900k with Z390 Aorus Pro + Dark Rock Pro 4
Feb 23, 2020
Hi all,
I am fairly new to overclocking but watched a few tutorials/researched a bit and would say I have a decent enough knowledge atm. I have a set up with a Z390 Aorus Pro and 9900k cooled by a dark rock pro 4. I know the dark rock pro 4 isnt great at cooling for heavy overclocks, but its all I have atm before an upgrade is possible.
Onto the overclocking, I have left my settings default optimised apart from I enabled XMP for RAM and I boosted the clock to 4.7ghz + 1.280v. I have ran this on Aida 64 stress test for a few hours maximum temperatures were around 80c on some cores which I believe is fairly ok?
I have been running a few benchmarks and found that if I turn off the setting which boosts some cores i.e. 5.2ghz core 1, 5.1ghz core 2 e.t.c down to 4.7ghz on the latter cores, the benchmark will run worse (because its locked to 4.7ghz). But the system runs stable with the boost on do you recommend I just leave it with boost as when I have tried to do a flat all cores overclock I have found it wont bench near enough (probably due to my cooler).
Just wondering what people would recommend ideally I would like a 5ghz over all cores or something but I know thats unrealistic.
Thanks for all your help in advance!
EDIT
Also would love recommendations for a cooler which will perform better, I have limited water cooling knowledge so a fairly easy solution would be good. I know about the Corsair H100i just wondered if its the best option!
Phaaze88
Herald
Liquid is really your only option for 9900K overclocking. Air coolers can barely handle the thing on stock settings.
Pushing 4.8ghz on the DRP 4 will push you into the high 80s, if not sub 90C.
Your DRP 4 likely performs just as well as, or slightly better than the H100i, a 240mm AIO, and is closer to a 280mm.
Best option is going straight for a 360mm AIO, like the Corsair H150, NZXT Kraken X72, or Cooler Master ML360R.
