I have a C2D 2.2 GHz running at stock speed (FSB 200MHz) on an ASUS P5GC-MX (945GC) board with 2 X 1 GB DDR2 667MHz Kingston ValueRAM.
CPU-Z shows that the memory runs at 333MH FSB😀RAM to be 3:5 and the timings to be CL - 5.0, tRCD -5, tRP - 5, tRAS - 15, tRC - 21. The SPD shows that it can run at 266MHz and 200MHz too. I gues if I set the memory to run at 200MHz the FSB😀RAM will be 1:1.
Which will get me better performace? Is it better to leave the memory running at 333MHz or to set it to run at 200MHz so that the FSB😀RAM runs at 1:1?
If so should I manually set the timings to those indicated in the SPD. The timings for 200MHz are 3.0,3,3,9,12. Or should I let the system decide the timings?
Thanks
Thanks
