[SOLVED] Advice regarding CX 450
Ravz
Great
Jan 28, 2020
107
8
95
Hello,
The PC specs are:
FX 6300, M5A78L-M/USB3, 2x4GB RAM, GTX 750Ti, 2 HDD's
I am planning to overclock this CPU a little bit. And probably but not sure I would upgrade the GPU to a 1050Ti or 1650 in the future.
Would CX450 be enough to run this system under full load?
I think we had this discussion already. Even with OC on the CPU and a GTX 1650 it's unlikely to use more than 350 watts. Would a more powerful PSU be better? Sure, but the CX450 can handle it if that's what your budget allows. If you can afford the CX550 go for it.
Reactions: Ravz
Reactions: Ravz
Ravz
Great
Jan 28, 2020
107
8
95
Thank you for the reply sir. And besides, I used the PSU calculator and entered the OC values and it says 379W load wattage recommending psu wattage of 429w. Would there still be some headroom with the PSU?
