Advice Sought: Upgrading current system
aitrus
5
Hey Everybody. I'm looking for advice on upgrading the family computer / my gaming machine. Specs below:
Approximate Purchase Date: Sometime in the next 12 months
Budget Range: I'd like to keep it under $500 or so.
System Usage from Most to Least Important:
The most important use is for budget balancing and writing (mostly on Word), but this is done less than 10% of the time the computer is used. Word and Excel are used a lot.
The machine is most often used for mid-level gaming and 'net surfing / youtube watching. Occasional DVD watching. No MMORPGs or online gaming. Strictly single person games. Occasionally download from Steam or the like, but I prefer to own physical disks when possible. The games I prefer are older, think Neverwinter Nights 2, the Dawn of War series, Icewind Dale / Baldur's Gate series, Command and Conquer series, etc. The most recent generation of games that I own but have not yet tried to play on the current system: The Witcher 1 and 2, Oblivion, Fallout 3, etc. I don't plan on buying any games that are have higher resource requirements than these for at least the next 5 years. I have a lot of games I haven't played yet, and I often replay old favorites.
No video processing or graphic editing will be done on this machine.
Parts Not Required: Starting with a Gateway DX4860-UB33P as seen here: https://www.newegg.com/Product/Product.aspx?Item=N82E16883113202
The only additions I have made is to install a GeForce 9500 GT and use a wireless keyboard and mouse. The onboard sound works fine, so a dedicated sound card isn't needed.
Preferred Website(s) for Parts: Newegg
Country: USA
Parts Preferences: I like Nvidia cards, no preference on memory brand, but would probably
Overclocking: Don't plan on it.
SLI or Crossfire: Nope
Monitor Resolution: I run a dual screen. Main screen is a HP W2072a at 1600x900. Second screen is a HP vp17 at 1280x1024.
Additional Comments: I don't want a new CPU, or to do a partial / complete rebuild. I want to maximize the potential available on this motherboard as much as possible within my budget. If I were doing this on my own I would do RAM and video card upgrades, and that's about it. However, I don't keep up with technology advances, so I have no idea what is too advanced for my setup given motherboard and processor limitations, much less what those limitations actually are. I also don't know what the best video card is that my system could accommodate, given that it's a PCIe 2.0.
Other than adding the GeForce, I haven't done a thing to the machine and it has served me well since I got it in 2013. Hopefully it can handle enough of an upgrade to serve for me another 4-5 years.
Thanks for taking the time to look over my system and for any recommendations or advice you might have.
You won't get much gaming from this, even a 9500 GT is so old and obsolete today. Next thing is that the pre built computer from your link only comes with a 300w PSU, assumable a crap quality unit, not enough for any decent GPU.
How much are you paying for that pre built computer? It's an old and outdated platform with a weak CPU.
I'd build something like this instead: PCPartPicker part list / Price breakdown by merchant
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor ($108.88 @ Amazon)
Motherboard: ASRock - A320M-DGS Micro ATX AM4 Motherboard ($49.99 @ Newegg)
Memory: Patriot - Viper Elite 8GB (2 x 4GB) DDR4-3000 Memory ($59.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($45.69 @ OutletPC)
Video Card: XFX - Radeon RX 550 2GB Video Card ($79.99 @ Amazon)
Case: Rosewill - Galaxy-03 ATX Mid Tower Case ($24.99 @ Amazon)
Power Supply: SeaSonic - S12II 520W 80+ Bronze Certified ATX Power Supply ($37.99 @ SuperBiiz)
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($92.99 @ Best Buy)
Total: $500.51
Generated by PCPartPicker 2017-10-29 12:23 EDT-0400
I'm not looking to buy this, I already own this. I'm looking to improve this as much as I can. I don't have enough savvy to build one from scratch, so that's not really an option, and I don't want to buy a new machine.
Thanks for the suggestions. However, I'm completely inexperienced at building a machine from scratch. I can replace RAM sticks and video cards, but taking a machine from parts to assembled to software uploaded is beyond my ken.
To be honest, by upgrading your current machine, changing RAM and GPU alone wont do it. You will want a faster CPU which means you have to change that as well and by adding a capable GPU, your current low quality and low wattage PSU wont cut it, so you will need to change that as well. Which btw. The suggested Seasonic S12 is not a safe unit, doesn't have OCP (Over Current Protection) so i will not recommend that. A Corsair CX450 instead should do it.
Hmm...lots to think on. It seems as if the consensus is that I need to just build my own from scratch. Does anybody have a good primer / step by step guide on building your own?
It's not really overly complicated; usually you should be able to find videos of people installing the parts you have (especially cases). Here's a guide from toms: http://www.tomshardware.com/reviews/build-your-own-pc,2601.html .
