Hey guys! I built this, budget gaming system like 2 years ago with help from this website. But now i think its time for an upgrade so I can play BF3 without a problem. I just have no clue how to upgrade and what to look for compatibility wise.
I think i need a new graphics card(s). that might mean a new MoBo, this ones MicroATX. I think i want to add more RAM too. And possible a new processor. I really don't know. I just need some great ideas and suggestions lol
Case
Cooler Master storm Scout. http://www.newegg.com/Product/Product.aspx?Item=N82E16811119196
MotherBoard
GIGABYTE GA-P55M-UD2 LGA 1156 Intel P55 Micro ATX. http://www.newegg.com/Product/Product.aspx?Item=N82E16813128405
RAM
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRH
GPU
XFX GeFORCE GTX260 576M 896MB DDR3. http://www.newegg.com/Product/Product.aspx?Item=N82E16814150329
CPU
Intel i5 quad-core i5-750 LGA1156 2.66GHz. http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
with a ^--COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7--^
PSU
OCZ 550W Fatal1ty. http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022&Tpk=fatal1ty
Hard Drive
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s 3.5
I was thinking at around $500 to spend but i have a feeling i might have to spend more lol
ANY advice/suggestions/ideas are much appreciated.
Thanks!
Case
MotherBoard
RAM
GPU
CPU
PSU
Hard Drive
Thanks!
