Advices for a gtx 1050 ti + i3 7100 build
Dennis_Orlando
18
Hi, I'm just a guy who needs some advices for a new pc, because that's pratically my first build. There are the components I was looking at
- CPU: i3-7100 3.9 Ghz
- GPU: Zotac gtx 1050 ti Mini
- MB: MSI-H110M Gaming
- RAM: Crucial 1x8GB DDR4-2133
- Storage: Western Digital RE4 1TB (7200rpm, SATA 2, 64mb of chace)
- Case + PSU: iTek case Replay 2.0, 500W, USB 3.0
can they go together?
About all power supplies that come with a case are garbage as yours is.
To make sure you get a working PC you need to buy a B250 board so the BIOS version will support the CPU.
I would also check the price of the G4600 processor about the same performance as the i3 7100.
Latest posts
