Advise and help
manok
9
nw build primary use ripping movies edditing pictures using cs4 light gaming internet watchung movies budget 700-1000 .I dont plan to over clock my monitor is acer 20 res 1400x900
Core i5 750 Processor
P7P55D-E PRO LGA 1156 P55 ATX Motherboard
Radeon HD 4670 IceQ 1024MB AGP 8x/4x
A-DATA Gaming Series 4GB (2 x 2GB) DDR3-1600 (PC3 12800) 240-Pin SDRAM Desktop Memory Mode
EarthWatts 650 Watt ATX 12V Power Supply
CM 690 II Advanced Mid-Tower ATX Case
windows 7 64bit
You cannot use the AGP video card you picked out, no board in the last 3 years or so will have an AGP slot, you need a PCI-E version of it, it will probably be cheaper actually, and you only need the 512MB version, you only need 1GB of VRAM for 1920x1080 or higher.
CS4 will appreciate the i5 750 so i would suggest sticking with the intel build, it wont get you much advantage with the games, but encoding and photoshop work will be accelerated a bit.
Rather than that A-DATA kit which seems to require 1.65-1.85V(anything over 1.65V can damage the memory controller on the CPU) so you may not be able to get it stable, the Gskill ECOs use only 1.35V and are just as fast. If you want to try OCing their low voltage will give you plenty of headroom to do so.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231319
Here's and AMD build. Under $1k is almost always AMD.
*EDIT* That's the maxed build, if you don't need the 5850 take it down to a 4850/5770.
