Hi,
In september last year I have created a thread here asking for an advise for my first build but some things went wrong and I decided to stay with my current StoneAge PC (Dual core Q6600 and GTX650) which is not even good enough for internet surfing nowadays. I'm actually glad I havent bought anything back in september as I can get much better parts at about the same price tag now.
What am I looking for?
A PC for an entertainment that will handle anything I throw at it including latest AAA games.
My target:
To build a future proof PC at a reasonable price (I know there is no future proofing when it comes to PCs but I believe some builds might last a bit longer than others. I want to keep it upgrade free for at least 3-4 years).
I've saved some build examples on pcpartpicker to start discussion with:
Z97 Build
X99 Build
Z97 WC Build
X99 WC Build
Hopefully with your help I can make right decisions.
First of all I need to decide whether X99 will be more future proof and worth a £400 ($600) premium as well as silent and higher performing operation of water cooling loop worth £600 ($900) added to the cost of any of above builds. Once decision is made about it I can move forward and seek for an advise on parts I've chosen.
BTW, I'm not a rich guy and only earning about £20k ($30k) annually ($24k on hand) therefore I can hardly afford any of above builds. So, price matters!
I wish to be an American at this point since prices for PC hardware are insane in EU. All of the parts are nearly 2 times cheaper in America...
Thank you.
My target:
Z97 Build
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor (£259.76 @ Scan.co.uk)
CPU Cooler: Corsair H110i GTX 104.7 CFM Liquid CPU Cooler (£109.99)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste (£4.99)
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard (£167.96 @ Scan.co.uk)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-2400 Memory (£79.99 @ Scan.co.uk)
Storage: Samsung 850 EVO-Series 1TB 2.5" Solid State Drive (£286.62 @ Scan.co.uk)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive (£74.76 @ Scan.co.uk)
Video Card: EVGA GeForce GTX 980 Ti 6GB Classified ACX 2.0+ Video Card (£619.18)
Case: Corsair 750D ATX Full Tower Case (£136.50 @ Scan.co.uk)
Power Supply: Corsair 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply (£170.52 @ Scan.co.uk)
Optical Drive: LG BH10LS30 Blu-Ray/DVD/CD Writer (Purchased For £135.00)
Operating System: Microsoft Windows 8.1 Pro OEM (64-bit) (Purchased For £110.00)
Case Fan: Corsair Air Series AF140 Quiet Edition 67.8 CFM 140mm Fan (£14.57 @ Scan.co.uk)
Monitor: Acer XB270HU bprz 144Hz 27.0" Monitor (£701.12 @ Scan.co.uk)
Keyboard: Corsair K70 RGB Wired Gaming Keyboard (£119.99)
Mouse: Mad Catz R.A.T. 5 Wired Laser Mouse (Purchased For £45.00)
Other: Logitech Z4 2.1 Speakers (Purchased For £75.00)
Other: Asus Strix 7.1 Headset (£153.47)
Other: NZXT HUE RGB Color Changing LED Controller (£19.99)
Other: [2x] EK 4-Fan PWM Splitter (£10.90)
Other: [3x] Corsair PWM SP120 Fan Dual Pack (£73.62)
Other: Corsair PWM SP120 Fan (£13.34)
Other: Sony Bravia 32" KDL-32EX523 LED LCD 1080p 60hz (Purchased For £450.00)
Total: £3832.27
Generated by PCPartPicker 2015-07-23 01:37 BST+0100
Total: £3832.27
X99 Build
CPU: Intel Core i7-5930K 3.5GHz 6-Core Processor (£455.00 @ Scan.co.uk)
Motherboard: Asus RAMPAGE V EXTREME EATX LGA2011-3 Motherboard (£340.79 @ Scan.co.uk)
Memory: Corsair Vengeance LPX 16GB (4 x 4GB) DDR4-3000 Memory (£126.13 @ Scan.co.uk)
Other: Sony Bravi?a 32" KDL-?32EX523 LE?D LCD 1080?p 60hz (Purchased For £450.00)
Total: £4246.48
Generated by PCPartPicker 2015-07-23 01:41 BST+0100
Total: £4246.48
Z97 WC Build
Other: EK-CoolStream XE 360 Triple Water Cooling Radiator (£82.03)
Other: EK-CoolStream XE 240 Double Water Cooling Radiator (£61.63)
Other: EK-CoolStream PE 240 Dual Radiator (£50.57)
Other: EK-FC Titan X/980Ti Nickel Acetal Water Block (£87.56)
Other: EK-FC GTX TITAN X/980Ti Backplate - Black (£23.87)
Other: EK-Supremacy EVO - Acetal+Nickel CPU Water Block (£51.72)
Other: EK-XRES 140 D5 PWM with Pump (£105.47)
Other: EK-D5 Cover Kit (Black) Acetal (£14.92)
Other: [2L] Mayhems Pastel Orange Coolant (£29.98)
Other: Masterkleer Tubing PVC 12.7/9.5mm (3/8"ID) clear 3.3m (10ft) (£12.98)
Other: [6x] Phobya 13/10mm compression fitting 90° revolvable G1/4 - black nickel (£19.37)
Other: [8x] Phobya 13/10mm screw-on fitting outer thread 1/4 - black nickel (£18.72)
Other: [1x] Phobya 13/10mm compression fitting 45° revolvable G1/4 - black nickel (£3.90)
Other: [1x] Aquacomputer Temperature sensor internal/external thread G1/4 (£8.96)
Other: Scan Hose Cutter Plastic (£3.58)
Other: [1x] Monsoon Screw Plug G1/4 - Matte Black (£2.72)
Other: [1x] Alphacool Angled Adaptor 90° Revolvable G1/4 outer thread to G1/4 inner thread - Deep Black (£3.30)
Total: £4303.56
Generated by PCPartPicker 2015-07-23 01:46 BST+0100
Total: £4303.56
X99 WC Build
Total: £4717.77
Generated by PCPartPicker 2015-07-23 01:47 BST+0100
Total: £4717.77
Thank you.
