G
Guest
Guest
Archived from groups: microsoft.public.win2000.setup (More info?)
Hi all,
got called to a friends house who has win2k SP4 installed and was having
trouble with adware, and virus infections. When I first got there I
used McAfee's Stinger file for a quick check of major/common infections,
None were found. I even tried "fprotdos" run in safe mode, but it found
nothing either. (I wasn't sure it would even run since it's a DOS
program, but it "appeared" to run, but didn't find anything) I then
updated and ran Spybot Search and Destroy, and Adaware 6, Norton 2004,
with latest updates, and finally I installed Trojan Hunter 3.8 with
latest defs.
All those programs found several hundred "at risk" files.
Some of the files resided in the "RECYCLER" folder, and while most could
be manually deleted (in Windows Explorer), a few couldn't, one was
named: S-1-5-21-220523388-152049171-854245398-1001
the other files that Norton lists that refer back to that file are:
Dc11.exe Adware Ezula
Dc12.exe Adware Incredifind
Dc13.exe Adware StatBlaster
Dc14.exe Adware StatBlaster
Dc15.exe Adware StatBlaster
C:\WINNT\SYSTEM32\Gay1ZPSb.exe (I was able to manually delete this one
Ran another Norton scan of the system32 folder and came up with several
different files showing as "at risk", Norton deleted all but 2 this time,
RtaWJ.exe and SczOOJ3.exe were the ones left and couldn't be deleted.
Is there no DOS in Win2000??????? How do I manually remove these
without starting windows???? She is using NTFS. There is a 31M
partition (?) that is FAT or FAT32, though I only see it when
defragging, I don't know how to 'use' it. ???
When Norton showed me the infected or at risk files, I deleted them,
then the ones it couldn't remove I chose to "skip" instead of "Exclude"
them at the final window..
I assume "excluding" them means they would be ignored on the next scan.
I rescanned immediately and the
3rd time found 5 new 'infected' files, deleted most, but still left the
SczOOJ3.exe file.
4th time: found 9 new files, left Vbcv2.exe behind. ??
5th time: found 9 new files, left 2: MuwqK7ev.exe and Usd13Q.exe
Help!!! these scans were run one right after the other, so these files
are propagating faster than I can remove them. ???
Is there another program that will clean these? or some way to access
them without having them "run" when booting up to windows? I've always
been able to get the HD clean before using the above combination of
programs in win98, but this one is baffling me as I'm not that versed in
win2000.
ANY ideas of what I can do now would be greatly appreciated. I spent 7
hours messing with these last night and just couldn't get past this.
thanks,
niteowl
Hi all,
latest defs.
SczOOJ3.exe file.
win2000.
thanks,
niteowl
