Adware Removal required hao123
Click on the 3 little bars on the right hand corner below the red x.
Go to settings.
At the top you should see the words on startup. Where it says open a specific page or set of pages click. Set pages
Delete any startup pages that you dont' want.
Type in what you do want.
Press ok.
Go to settings.
Press ok.
Yes as yeticorn said, you should also do a deep spyware clean in safe mode. Usually that solves the problem if not the problem might be deeper you might have to find the program by hand or mess with the targeting of chrome. It probably infected other internet browsers you had i'm assuming.
Just be careful if i know my bloatware, it's might come back with a vengeance. Also be careful about what you download, especially when installing always do a custom install so you can make sure you know what's being installed. Gl.
