aerocool sixth element front panel removal
fieldsy
34
I have taken both sides off of the tower, but I am not sure how to remove the front panel.
There is a gap at the bottom of the case, between the front panel and the case itself. There are also plastic, compressible screws?
Do I just pull from the bottom, or do I undo the screws and then pull?
Hi fieldsy
If they are plastic compressable screws you should be able to pull at the bottom to remove the front panel , try squeezing the plastic heads where they come through the inside of the case with a pair of pliers from the bottom first working your way up , pulling gently as you go and see if that will work
Hi fieldsy
Thanks. I pulled from the gap in the bottom, and it came away with ease
