Question After 5 minutes of gaming, monitor blacks out, PC still running but white light on GPU is blinking ?
Feb 26, 2023
16
4
15
CPU: ryzen 5 3600x
Motherboard: asrock b450 pro
Ram: 2x8 ddr4
SSD/HDD: 1x5400rpm hdd 500gb, 1x5400rpm 2tb hdd, 1 nvme 512gb ssd
GPU: rx 580 8gb gigabyte gaming edition
PSU: trendsonic eco power 700w
Chassis: zalman zalman n5 of
OS: Win 10
Monitor: Samsung LC24RG50FZRXUF 24" 144HZ
I'm wondering if its a loose cable (however I dont think it is) or a psu problem, which in my opinion is more likely, im just not sure how to check if it's a psu issue, and can it possibly be something else? the pc runs fine if im just browsing, but if i enter a game it crashes about 5 minutes in, no matter the game. i ran sfc scannow but i dont think that helped much.
CPU: ryzen 5 3600x
Ram: 2x8 ddr4
OS: win 10
Monitor:
SAMSUNG LC24RG50FZRXUF 24 INCH 144HZ​
PSU is the most obvious cause, both from the symptoms and the fact that you have an extremely cheap, group-regulated PSU that had no business ever being turned on with this PC. Replace that first -- this should have been done under any and all circumstances -- and cross your fingers that it's the cause of this problem *and* that it didn't take anything like your GPU which is, which isn't uncommon with these junk-tier PSUs.
Reactions: Phillip Corcoran
CPU: ryzen 5 3600x
Ram: 2x8 ddr4
OS: win 10
Monitor:
Occasionally there is a difference between optical and HDMI monitor connections.
